The tilt and trim on my motor has been making a growling noise when the tilt gets in certain positions. I haven't done anything with this unit before so I thought I would start with the fluid check / fill. Is the procedure just to tilt it up, unscrew the fill screw, fill it up and screw it back in? Do I have to worry about bleeding it or anything else?
I saw in my manual it recommends Dexron II ATF. I have Dexron III ATF. Can I use that or does it have to be II?
Thanks for your help.
