Cold weather blues....
Engine/Heads/Carbs 89 Excell.
Electronics and everything bolted to it 98 150 V-Max.
Been running fine for 9 months. Several weeks ago it began to get difficult to "keep" running when 1st started in the morning. (just figured it was cold natured and cold air and cold water).
Spun hub in 25p 6200 wot prop.
Replaced with 23p which then turned wot to 6400 rpm.
Not sure if that had anything to do with this problem since "some" of these symptoms had already begun...
1. Seems to be getting harder and harder to keep it running/idling prior to 1st launch (four mornings per week).
2. After a 5-10 mile wide open sprint, set it down and idle for a few minutes, take off again...and...it bogs and surges intermittently and will hold at lower rpm...but...slowly it will finally get all it's speed/rpm back. (may take it 5miles to get there though).
3. It will fire up and idle fine the rest of the day though.
4. Couple months now it has what seems like an intermittent miss/spit/sputter/surge? on and off at a hard idle (under a load, going just fast enough to keep it from trying to plane....or, as fast as you can push the idle speed in a no wake zone).
Fuel pump Mallory elect. Holds 6lbs at idle and while reving it in a tub of water. No drop in pressure, No pressure spikes. Regulator located on motor right at the carbs. New fuel lines. Yamalube in every tank. 30gallon tank tank clean and run about 40gal of fuel through it every week. Good water pressure.
JUST: removed, cleaned, re-adjusted and/or checked carb settings (kitted them 8 months ago). Compression 145lbs each EXCEPT the bottom two cylinders which are 130lbs each. New plugs. No linkages/controls are sticking, hanging, or getting bound up. Timing all correct.
Plugs clean, but, DARK DARK BROWN prior to changing them. AND...Few drops of moisture on one of the lower 130lb cylinders. (figured it was just condensation from setting a couple of days). Can't find any water or moisture after playing with it in a tub.
Reeds are hydtrotech and going on two years use now.
Acts to me like it's running rich or loading up for some reason. Even in a tub at part throttle it just doesn't "sound" right. Not crisp and smooth throttle response just revving it. It's more of crackling/loading up sound.
Any ideas? and....HOW to check for leakdown in a 2stroke? Rings leakdown wouldn't be a problem (just hold the piston up) and maybe that would tell me if I've got a blow headgasket into the water port, but, How to leakdown test in order to know if I've got a blown crankshaft seal or crankshaft ring?
Just where do I go from here. It doesn't bang/pop/backfire. It does surge/bog though and I think I've worked my way from the tank to the intake manifold and found nothing wrong. What next?
