!984 Johnson 115 V4
elcid
Lower unit is leaking lubricant thru exhaust port. I have ordered a manual today but would like to remove lower unit this w/e. In the past I have dropped lower units on I/O. I just want to be sure if I start prior to receiving the manual I don't foul something up. I would assume if everything is unbolted the lower unit should drop easily. I have seen several articles that mention disconnecting gear linkage. Where is this located. Also would assume the bolts to be removed would be the 2 located on either side as well as the 2 located above the prop. Any help would be appreciated. Boating season is short in Ohio compared to below Myrtle Beach so I want to get going. Is there a specific gear the motor should be engaged before dropping?<br /><br />Thanks Elcid
D
DJ
Guest
Re: !984 Johnson 115 V4
elcid,<br /><br />You'll need to disconnect the gear linkage first. You will see a rod protruding up from the lower cowl pan just below and behind the lower carburetor. That's the linkage, a real bugger to get to. <br /><br />It helps if it is in reverse.<br /><br />Otherwise, you've got it.
jobassing
i found the linkage bolt not to bad with a foot of extinsion and a ujoint on a 1/4 in drive rachect to get it on type the bolt to the socket :p
