Re: 99 250 ox66 unstable rpm's high speed cutout
ok, let's back up....if you go to yamaha's site and go to service you can look at very detailed drawings of every part of your engine for free, with numbered parts and a corresponding list to tell you what each numbered part is...it'll show you the filters...it really helps if you know at least the very basic things like the filter in the vst tank, that is called for replacement every 100 hrs...please look at the yamaha site, it's free....now, the way I clean the o2 sensor and the way it's taught at Yamaha school is with a torch, but you have to be careful....just heat the 'can' until it's a nice cherry red to burn off all the carbon/crap, you may spray it with electrical cleaner when it cools, DON'T get any fingerprints on it or ANYTHING else....again back to drawings...there is a tube that you'll see the end of coming from engine into sensor location, this feeds the sensor w/ exhaust to read...pull it out towards you and clean it out (drill bit(careful), cleaner, soak...it'll be clogged off completely I think..get it clean...you'll need to order a gasket kit for re-isntall....let us know how it goes....
