Re: 99 350 5.7L Mercruiser - What outdrive?
Thanks Don,
Another question. Right where the lower unit is attached to the upper unit, there is a small drain hole on either side of the drive. I noticed that there is a small amount of oil that is draining from these two holes. I am trying to isolate where that would be coming from. My guesses are, the upper drive shaft seal, the quad ring, or the remote drive fill line. I know I need to drain and pressure test the drive....just trying to eliminate where the leak is not coming from. I am not familiar with the gen 2 drives, but don't see many differences from the type 1 drive I previously owned. Any help would be appreciated.
Also, is there a manual online for this drive and engine?
Thanks
