GoFastr
- Joined
- Aug 26, 2012
- 73
Starts and runs well. When I turn the key on the tach drops to zero and stays there. With afully charged battery running the battery indicates approx. 12.5v and when I fast idle, it dips t ever so slightly downward.
Today I changed the stator with no change. The old stator had 2 yellow wires, 1 green w/white stripe and 1 white w/green stripe. The new one had the 2 yellows, 1 solid green and 1 solid white?
I'm not savvy with outboards and learning on the fly with each little issue I encounter. Inside the stator ring is another circular black ring with wires. What is that called and what is it's function?
I'm assuming where the 2yellows lead is the regulator. I could see how that could affect charging. But would it affect the tach by sending to zero or could there be two problems?
History....All was working fine until it over heated on me, then the tach zero'd out and a known good battery went dead one day after a weekend of use after the overheat (impeller change) and the tach quit working. All wires and connectors appear fine.
Any help or explanations on what does what would be appreciated.
