New boat owner here. My 1999 1750 seems to be using lube oil. It has a reservoir in the engine compartment and I have filled the reservoir up to the fill line more than once in the last 12 hours of operation. Yesterday we went out for about 2 hours of run time and it went from the full line to about 1/3 down towards the low line. There isn't anything obvious on the outdrive as I park it right out front and have never seen anything drip off of the outdrive.
For some back ground; before I bought the boat last month we had an "authorized" Mercruiser shop pull the outdrive and check it out. He found a oil shaft seal (part# 26-892361) that needed to be replaced and in the process the gear lube was changed. Other than that he said everything looked fine.
Could it be that the oil usage I'm seeing ( a few ounces) is either normal or will it stop consuming soon because the previous lube change left air in the housing? I think the total usage in the past 12 hours of run time is maybe a full reservoir bottle or slightly less but being new to these I'm a bit concerned.
Ideas or suggestions anyone?
thanx,
jeff
thanx,
jeff
