I sure goofed.:facepalm: While removing the bell housing, I snapped the fitting in the gimbal housing where the gear oil tube connects. Anybody know how to get the fitting out of the gimbal housing? I could also use some guidance on replacing the shift bellows. Do I need to locate the linkage under the hood, disconnect it, pull it out of the gimbal housing and then slide the bellow on from the linkage end?
