I have a problem with a slight surge/hesitation that can be felt while running,usually at midrange speeds. This started after the injector bracket recall was performed. The factory tech relaced all injectors, computer,tps sensor. It might seem to run ok for a day , then it reoccurs.<br />The fuel pump, compression test was also done. I get no check engine lights. This problem is very annoying and I need help or suggestions please. I read elsewhere that it could be the bracket that holds the crankshaft sensor flexing, causing the gap to change at certain speeds. Please give me some advice on this,<br /><br />Thanks a million
