Hello everyone. I recently have been having some issues with my Ficht and finally got a couple of them straightened out. Took it out on a test run last night and the motor started squeaking so I brought it back to the dock. This afternoon I took it back out after spraying some wd40 on the shaft under the stator to see if that's what was squeaking and it helped. Although after maybe 10 minutes or so of running the squeak slowly came back. Has anyone had this problem or knows what could be causing the squeak? It's fairly loud and does it in and out of gear. Thanks in advance!
