Re: 99 Honda Outboard 25 mhp- Slow
Just because that is the factory prop does'nt mean it is right for your application.I would hope that dealer copensated for the added weight and propped you as such but that can be a balancing act.It might be usefull to also see if you are also actually,mechanically,achieveing wide open throttle.With the remote or twist grip at wide open ,all carbs should be at the stop if rigged properly.
