'99 Jeep Cherokee Instrument Panel Problems
mike64
I have weird problems with the instrument panel on my '99 Jeep Cherokee Sport. My "airbag" light will come on while I'm driving, accompanied by the failure of different instruments-- sometimes it's just the speedo and tach, sometimes it's all instruments. Each time it only lasts for a couple minutes and everything starts to work again. This can happen 2 or 3 times in a 25 minute commute to work, or not for a week at a time.
This intermittent problem has been going on for about a year now. Haven't dealt with it because it never lasts long, but it seems like it's happening more often recently. Anyone got any idea what could be failing-- computer module, wiring short, etc..?
MXZ500
Re: '99 Jeep Cherokee Instrument Panel Problems
Hi
I've heard of Wranglers (TJ) had the same problem with the connector on the
back of instrument panel. But if you did a search on some of the Jeep forums
You most likely will find the right answers.
try
http://www.jeepkings.ca/
or
http://www.jeeps-offroad.com/
A little search and I found this
http://panhandle4x4.phpbbnow.com/viewtopic.php?p=3032&sid=2d7b30bac41e89b27267cecbf6781c7d
Hope this helps
cheers
lowkee
Try going over a few bumps (enough to jar it) and see if it causes the dash to weird out. If so, I'd vote the connector in the back of it as well. Otherwise I'm at a loss. New cars = mysterious magical beasts to me.
