MikePags
- Joined
- Jul 28, 2007
- 33
Hi, my first post,, please help me. I have a 99 Seaswirl Striper CC with a 99 Johnson 150 Ocean Pro. Here's the prob: I can start cold priming the bulb, and can literaly run flawlessly at 4k RPM for miles. My problem is when I go to restart after shutting down. I have to re-prime the bulb again as there is none to little fuel in the line and mostly air. Sometimes the motor runs crappy for a few minutes afterwards until the air is gone. Here is what I have done so far.
1. Replaced the primer bulb 2 times with new, one is a Yamaha.
2. Eliminated the ball check valve at the fuel tank.
3. Checked all fuel lines and vent line for leaks and or clogs.
I suspect something at the motor, fuel pump or some diaphram thingy that is letting air into the system. Any trouble shooting ideas, and diagrams of the fuel system that would point to where I might start taking things apart for diagnosis. Thanks so much. Mike
