I have been using Penzoil Semi Synthetic TC-W3 oil in my 150, my dealership just had it in for repairs and claims that using that oil is what killed my VRO pump even though it is the fuel side that is bad. Does this seem like it could actually be the problem or did the pump probably just die from wear.
Second question how important is it that I use XD-30 in this motor, is it going to cause anyless carbon build up than the penzoil and it is going to keep the fuel system from gumming up the way they are saying it is from the penzoil. If I should really be running the Johnson oil I have no problem with that I just have a boat load of the penzoil in the barn.
Thanks for any input you all may have.
