bowtie4x4295
- Joined
- Jun 9, 2008
- 45
I recently purchase a 1999 Marada 2102CRS Performance Series bowrider by Armada Powerboats, it has a 5.0EFI. During acceleration it lists to the port side. I seems to get better once up to speed and trimmed properly. The boat only has 103 total hours. I am concerned about water saturation, but it is in such nice shape and with so few hours I am doubting that is the issue. I pulled the tank access panel near the stern and everything looks good and is coated in some pretty thick black substance. I am wondering if it just might be a characteristic of the hull design. I have checked the hull for inconsistencies all over bottom and cant find any. I also think it has been going on for a while due to it having Bennett Trim Tabs installed, so I can correct the issue, but I still want to know why. I measured it while sitting in calm water and at stern both sides measured equal distance to the rub rail, on the sides under the windshield it measured 1 inch lower on port side and 1 inch higher on starboard side. I would think if it were water saturated it would be worse than this. The boat is 3250lbs dry. I have pics of boat if needed. The one thing I am seriously thinking is the 19P High Five prop might be doing it, but would it be that noticeable. I need a new prop any way, I can bounce this thing off the rev limiter at 5400 with no effort at all, I have to keep checking the tach to keep them aroung 4600. I am thinking about a 3 blade 21P. BTW the hydrofoil was the first thing to go, and it help some with the listing, but it still does it enough to make me wonder why...
Thanks, Mike
Thanks, Mike
