JohnKorte
- Joined
- Dec 30, 2013
- 58
Took the boat out for the first time this year. Had 1/2 tank of fuel from winter, put in bottle of seafoam added 5-6 gallons of fuel. Started just fine and boated out to the other side of lake No problem. When I idled down the engine died, It had problems starting. When I finally started the engine it would idle fine in neutral but once I put it in gear it would die. It took awhile but I was able to idle high in neutral and quickly put it in gear and get back to the dock. So it ran ok at high RPM but will not run in gear at low rpm. Any suggestions??
Thanks,
john
Thanks,
john
