Outboard Mike
- Joined
- Apr 26, 2009
- 55
Been working on a friends 99 40hp 4 stroke motor. It was in a no start condition when I started working on it. It had not been run much for the past few years and had some old gas. I replaced fuel tank with new gas and quickleen, primer pump, fuel lines from the motor to the tank, fuel filter and the fuel pump(was bad). I took off the fuel lines on the carbs and blew out all the old gas that was in the carbs with a compressor. I got the engine running but it would stall on acceleration. I tried to adjust the idle screw and carbs by pinching off the top and bottom carb lines. I don't have the gauges to sync the carbs and my friend needs the boat next week. How can I adjust the carbs without the gauges?? I do have a manual and it does not show adjustments without gauges,
