I have a 99 model 225 FICHT with a tilt and trim problem. The motor will trim down, but not up. I have 1st changed the relays, then the relay panel or the box where the relays go and the motor will not go up. I no the motor is good because I wired stright from the battery to the trim wire plug that goes to the relay box and it worked both ways. Dose anyone have any suggestions?
Thanks CR
Thanks CR
