99 yukon cranks but no start?? 5.7
ezbtr
Arghhhh now at 93K cranks but won't start - dont hear fuel pump charging like I always do, pulled ignition relay and AM getting juice across relay terminals, bad relay? New cap, rotor, plugs 2 mos. ago and was running perfect til I parked it at home last night. I'm not thinking fuel pump as I don't hear it charging.
Update: I swapped relays no change, and I AM getting spark to the plugs.
Thanks!
Dunaruna
Re: 99 yukon cranks but no start?? 5.7
You need to find the fuel pump relay, not ignition relay.
It's a faulty relay or pump.
Bob_VT
Fuel pump in the tank is a common failure. I have seen mechanics hit the tank HARD with a rubber mallet while it is being cranked and sometimes it it restarts the fuel pump..... but not at all a permanent fix. My WAG (Wild A55 Guess) is the fuel pump.
jimr
I agree with Bob have someone crank it over and give it a wack with a hammer. it may or may not work.
