!995 Starcraft Superfisherman 170
budski
This boat is in great shape but going to refurbish and upgrade motor from a 1995 Merc 75, to a 2000 Merc Optimax 135, and it's going to be my keeper.
budski
No Title
2000 Mercury Optimax 2 stroke oil injected.
budski
No Title
My son and I got it gutted, floor is a little stained but solid, going to leave it.
Tnstratofam
She almost looks ready to go as is. How much of a rebuild is she going to need? I'm sure by the time you and your son are finished she'll be awesome.
dozerII
No time wasted on this one John, but I guess when it is storming out side what else can you do.
budski
No Title
Optimax is mounted,
budski
No Title
Some progress, got the bow and stern decks and some sidewalls carpeted.
budski
Thanks JB not to crazy about the aluminum trim on the hatches but a lot easier ti reinstall.
budski
No Title
Got the vinyl floor installed and interior mostly carpeted, just dry fitted so far.
dozerII
Looks great John, your going to have to come out west to teach me how to lay carpet like that.:D
budski
Thanks Glen it's not really as hard as it looks just time consuming.
budski
No Title
got the rear deck almost done built an access door, replaced snap on vinyl, still only dry fitted.
sublauxation
Looks great, I'm nearly at this point and I've got a couple questions if you don't mind..
What brand vinyl did you use?
Are you going to screw the decking down through the vinyl or did you put it on afterwards?
Did you scrape all the glue off the aluminum before putting on the new carpet?
budski
Thanks sub. I used nautolex vinyl flooring, The floor was good so I glued the vinyl directly to it, I scraped most of the glue off the aluminum before I reapplied new carpet.
sublauxation
Thanks for the info. I've been debating between carpeting everything on mine or doing it like yours with a vinyl deck and everything else carpeted. I was leaning towards carpeting everything but thankfully I haven't bought all the carpet yet because looking at your pics I think I've changed my mind again. Do you know what color that is. From the pics I can't tell if yours is the Storm Grey or possibly the Shark color.
budski
Actually it's storm grey, and I personally think that vinyl is a better choice, easy to clean and doesn't hold moisture, your floor will last longer, it's more costly than carpet but will last longer.
budski
Thanks JB, we're getting there, have everyting carpeted but it all needs to be reattached still dry fitted, hoping to get that done this weekend, then re install the motor and do the wiring.
