Re: A bagging idea
I've been meaning to try this... it should work quite well for stringers. The ability to glass around any shape would be nice, as well as getting the optimum amount of resin.
Somewhere in another thread Yacht Dr. posted about vacuum bagging repairs to a hull core... vacuum bags are a well known way for pro boat builders to "clamp" odd shapes and make sure fiberglass lays down in place. If you're good you can get a similar ratio of resin to glass in hand layup, but you have to follow the rules of filleting and rounding edges so bubbles don't form. Not so much with a vacuum bag.
The big thing is that you have to have a good vacuum pump setup... a shop vac won't even come close. You need a real vacuum pump, preferably a backup in case the first one flakes out, fittings, bags, tubing, and various other items, preferably including a vacuum switch to turn off the pump when the vacuum is holding and turn it back on if a leak happens.
But you can get most of this stuff or substitutes for it pretty cheaply, so I'm going to be trying it soon using polyethylene garbage bags for the outer plastic, polyethylene pillow fill for flow media, nylon taffeta fabric for peel ply (non stick layer against the glass) and custom made fittings from my shop, with PVC tubing for catching extra resin and as a "vacuum store".
I would think the hard part for stringers would be sealing the edges of the bag against the inner hull.
Do this and post pics
Erik
