petrolhead
- Joined
- Oct 16, 2003
- 614
Picked up what I hope will prove to be a real bargain today, a Johnson 4hp model J4BRECR, which I believe is a '98?<br />It was cheap, and I mean really cheap at £25 (US$45), basically because it has been submerged (fresh water) for a few days, and the owner couldn't afford, or wasn't prepared to pay, the bill to have it cleaned out by the shop. At their prices I'm hardly surprised, for the cost of a 1/2 days work he could buy himself a nearly new motor, which is exactly what he did!<br />Anyway, as soon as it was recovered it was drained of water and oiled, it does have a fair bit of fine silt inside the cover, and I suspect in the air silencer and carb too, both of which I'll strip and clean, but it turns over smoothly and the shop assured me the compression is good. Haven't checked it for spark yet, I'll do that later.<br />What I want to know for now is how the STOP switch works? I can see it's spring loaded and appears to be permanently in the OFF (pressed) position, there's a little plastic gizmo attached to the tiller labelled EMERGENCY RESTART CLIP, what's that all about then? Presumably you fit it under the STOP button to hold it out for starting, but what's the "emergency start" bit about? In normal operation how do you start and stop the motor?
