SS MAYFLOAT
- Joined
- May 17, 2001
- 6,372
Yep, I'm out of the cellar! Its confirmed now, I have a dock with shore power. Its been 3 years on the list and now I'm there.<br /><br />Here is the scoop. Boat is a cabin cruiser (make/year unimportant) I'm installing the compressor in the bilge, evaporator/air handler in the head. and I want to put the condenser coil under the swim deck. <br /><br />I will only be using the A/C while on shore power. I was thinking that with the coil submerged that I would get enough thermal transfer into the water. Of course while I'm underway the coil would then be out of the flow of water. <br /><br />This way I won't need to mount the coil with fans running making noise.<br /><br />With the air handler in the head, all the condesate water can go into the holding tank.<br /><br />So what do you think? BTW I'm certified in the field. Thanks....
