stevenhickeys
- Joined
- Aug 1, 2012
- 53
Hello,
Recently, I removed my L/U from my O/D to replace the impeller. I noticed the old impeller had some of the blades broken off and was wondering if these broken pieces could have worked their way into the motor block. My Starcraft American 20 has a 1976 165 Mercruser with a MC I outdrive. Should I worry about these blade pieces inside the block or could they most likely been flushed out of the system?
After removing the L/U, I also wanted to remove the upper section to take a look at the bellows and gimble. I removed the 6 lg nuts holding the upper unit, wiggled it and got a small separation where the gasket is, but I can't seem to get this Upper unit to come off. Is there some bolt, hose, or something else holding this thing on? I didn't want to start whacking it until I got some tips from the Pro's.
Thanks
SH
Thanks
SH
