Watermann
- Joined
- Jan 12, 2013
- 13,824
For those of you who do this all the time, I have a couple questions.
The center studs on the outer transom assembly are corroded from being inside soggy transom wood. I have replacements but wanted to know the best way of removing the 2 studs without ending up snapping them off. I've been soaking them with PB and plan on nut piling 2 nuts on the threads and using a pair of vice grips on the shaft at the same time to turn them out.
I pulled off the outer assembly with the bell housing still attached, would it be easier to mount it on the stern before trying to remove the hinge pins? The hinge pins for the bell housing are stuck on this one, yeah I have the special pin tool but not sure now much heat to apply to the locktite. Is a heat gun enough or do I need to break out the torch? I've reviewed the manual and know where to apply the heat just wondering how much heat it takes to get the job done.
