I am new to the forum and appreciate any help you can offer. I have been reading threads for a few weeks now, but can't find what I need. So, here goes.
I just bought a 1988 Wellcraft 210 classic with a 5.7 litre engine and Alpha one Merc out drive. I have had the boat out twice and it seems to run great and I am getting used to it after not having a boat for 30 years. Kids are grown and I can afford it again now.
I have several questions.
1. We went to see the Blue Angels last Saturday in Pensacola. We wanted to anchor in the bay, but when I tried to set the anchor it would not hold the boat. I was told I needed a chain which it doesn't have. Question is how big of a chain and how long should it be. The bottom is sandy around here in the Florida panhandle.
2. Also can someone give me an idea on how much fuel this boat uses per hour at cruising speed. I think that is about 3200 rpm. I don't have to get anywhere in a hurry so cruising speed is fine with me for most trips. The gas guage jumps around and then disappears when I am moving. I never know how much fuel I have and that will bite me one day I am sure.
3. Also my temp guage doesn't get much above 130 which is the low end of it. Is this normal? Don't want to over heat it.
4. Also there isn't anything showing on the oil pressure guage. I checked the dip stick and it was very low. I added 2 quarts to bring it up to the full mark, but now when I check it, it says it is low again. I don't want to run it again until I am sure the oil is ok. I can't see where any is leaking so it being low again after one trip is freaking me out. Should I check the oil when I am in the water or try to get the boat as level as I can in the driveway?
Thanks for any help.
I'm sure I will have lots more questions.
Thanks,
Jim
Thanks,
Jim
