A Crack At the Rib
OBJ
My 86' Rude 90hp has recently sustained and internal injury due to the ignorance of yours truly. The sleeve is showing a crack at one of the exhaust port ribs. The rib is OK. My friendly neighborhood machinists thinks it will be OK. He says he can bevel the crack a little so the rings won't catch, mic the sleeve for true and we not have to re-sleeve. I'm a little un-sure of this. Can some of you guys give me some opinions? I'm just about ready to say, "better safe than sorry" and re-sleeve the offending cylinder.<br /><br />Signed...Tongue in cheek in Ohio.... :confused:
Dhadley
Re: A Crack At the Rib
According to "the book" it needs to be resleeved. In the real world its OK. If it was going to catch a ring it would have already done so. <br /><br />At this point its a matter of how you feel. Do whatever makes you comfortable with the motor. If that means resleeving then go that way. <br /><br />Good luck!
OBJ
Dhadley....thanks for the post....I'm goin to sleep on it and give it some thought. :rolleyes:
