Ripfence
- Joined
- Apr 29, 2006
- 210
My boat has a three blade stainless steel 21p Mercury Laser II prop on a 19.5' Nitro powered by an 2006 optimax 150hp outboard. My wot is around 5,400 which is a little lower than it should be.
Anyway, I can run around 55-57mph with my current setup but I seldom ever do, I would like to trade top end for faster hole shot and staying on plane better at lower speeds. To do this I have decided that a four blade prop at 19p would do the trick. I would have tried trim tabs but the Nitro factory service tech said that due to the hull shape and swim platforms that they don't recommend trim tabs on this model. Going on the assumption that he right it looks like a prop is my only real choice, that being the case a $150 aluminum prop is more desireable than a $400 stainless.
My questions:
Can I get the desired results with a aluminum prop rather than stainless?
Some bass fisherman use aluminum props with the thought, "If I hit a rock then the aluminum will distort, taking the shock and preserve my lower unit" is there any truth to this theory?
Will the flex that aluminum has counteract the effects I am trying to achieve?
Are most aluminum props created equal or are there some aluminum props that are much better than others?
Are stainless steel props so much better than aluminum that I would be foolish to use anything other than steel?
My questions:
