beason
- Joined
- Mar 15, 2011
- 338
I did a little work on the engine, and boat in prep for this year. new plugs, starter, prop, and bilge float were completed by me. Bellows, impeller, gimbals, and shift cable were all done by a reputable shop. I went from a 21p prop to a 19p prop.
I started it here on the muffs before we left, and it fired up as soon as i hit the key, so i felt pretty good about it.
got the boat in the water, and made sure there wasn't any water coming in from the bellows, etc. Then went to fire it up. It took a bit to fire, and i ended up having to give it a little gas to get it to fire. Once it started it ran good. we did a little pass up the river, and checked for water again, before heading out to the lake. I noticed that it was not spinning as fast on the starter as it was here at the house. I can only assume this is because of the water resistance.
I was seeing temps of about 150 at cruising speed, but it would climb closer to 170 at WOT. I was seeing speeds right at 40mph and rpm about 3500. I think. Ill have to look at the gauge again to verify. These were both on the dash, no GPS speed.
Every time i shut off the boat it would diesel. and would be semi hard to start again.
I did notice better takeoff and a lot faster planing with the new prop, and i didnt see a drop of water in the bilge, so those are both +1!!
Sorry for the long post, so ill summarize.
merc 3.0l on a 99 searay 180
40mph @ 3500rpm @ WOT Is this acceptable?
what would cause dieseling, and having to give it throttle to start? None of the work i did messed with the carb adjustments.
slower spin on start up from the starter, in the water, opposed to on the muffs. Is this normal as well?
