1) Iam not sure what year it is but on the plate i can't read anything at all . The serial number listed by itself on a sticker shows OC288603 which when i looked on the serial to year i only see 7 digits on most . (Pic 1)
2) The tilt was working until just a bit ago. I wanted to lower the motor down and when i hit the switch it sounded ok but didn't move and then then started making gurgling noises . Is this a relief screw on top so i can lower it down ? Its not way up but its stuck there but the fill hole at this level is not full . I looked to see what oil to use but iam not sure . (Pic 2 and 3)
3) Theres a tube coming out in the 4th pic that is capped off but also cracked . What should i do with it and whats it for ?
