rhillman75
- Joined
- Jul 28, 2010
- 176
I just trade my pontoon for a 1996 Sylvan 196 w/ a 4.3L V6 Mercruiser Gen+. I was trying to get a manual for the boat (controls, dash lights, switches, etc... and with no avail... I can't find anything!) My main question is start-up procedure. I know the throttle forwards and reverse, however, how do you get it to idle at start up when it is cold? The owner said there was a button on the bottom center of the commander throttle arm that you need to push "in" for choke while you are starting in order to prevent the drive shaft from engaging. So my ? is...before you go to turn the key should you push that button in and slide the throttle a little forward and "hold" the button while you crank and then pull the throttle back to idle? I did get it started when cold without pushing the button but it did take a while. Any answers on startup would be GREAT!
