timharper89
- Joined
- Jun 24, 2018
- 277
First off, not sure if this is all in the correct subtopic. Sorry about that. I recently acquired a 1987 four winns sundowner 4.3 merc. I noticed it taking on water and found a tear in the drive bellows. I think I can figure out how to replace that from YouTube, but I found a few other issues. One is the screws holding the swim platform (only the two closest to the ladder) do not stay in. One catches and tightens, but it keeps unscrewing when weight is applied to the platform .The other (bottom screw) one just spins and seems to be stripped.
Second is I saw pink fluid in the bilge. Upon investigating, I traced it back to the trim tab reservoir. Not sure where it is leaking at the moment, but the area under it had lots of fluid. Any suggestions where to start? Tab motor is a bennett v351
Third is I found a pair of small (think speaker wire) red and black wires on the port side by the battery that don't connect to anything. I was able to trace them all the way back up to the dash area. They just went with all the other wires. The temp gauge doesn't function at the moment, and I wondered if that might be why. I'll attach pictures.
Fourth, I have a slight fuel (I think) odor coming from a small compartment to the bow side of the fuel tank. There is no odor in the engine compartment. I just cleaned the bilge as best as I could with dish soap yesterday. There doesn't seem to be fuel pooling anywhere at the moment. Any ideas here?
Fifth, last time I had it out, it started perfectly fine on the first crank very quickly. It then died idling. I started it a few more times, which were hard starts, and then it died idling again. This happened 4 times before I gave up and just put it back on the trailer. Started it again yesterday ,and it fired right up. It was in my yard, so I didn't let it idle (didn't have a hose but was just curious). Fuel filter? Pump? Should I run some Seafoam through it?
Sixth, power steering pump doesn't seem to work (pretty hard to steer). There is fluid in the pump JUST under the full line. Does this mean tth pump is bad?
Finally..not really something broken (I don't think). I have trouble getting out of the hole with a full load (we have to send people into the cabin to put the bow down). Motor is trimmed all the way down, trim tabs up (have tried many configurations, but this seemed to be the most successful). Max speed was around 40 on the Speedo with 3 adults. Max rpm was about 4200 this is WOT. It is less (32mph 3800rpm at WOT) with a full (6 adults) load. I'll post a pic of my prop. I'm wondering/hoping it is prop related. I believe it's 23 pitch. I'm new to this, so I'm not sure what it all means.
I'll attach pictures of other things as well. Thanks in advance for the help!
