a fun puzzle (1967 Johnson?)
yodel3
I was given this outboard which has been guessed to be a 1967 by the forum gurus and I hope to make it run. The problem for today is that I can't get spark. The previous owner installed an electric starter (or reinstalled) and I am not sure if everything is correct. If you follow the link below, you can see where he connected wires to the motor and to three switches on the side of the housing. There is a rough drawing of how the three switches are hooked up. They leave the page in the same order as they connect to the motor in the picture left to right. Sorry if that is confusing.
When I hook everything up, the starter works, spinning the flywheel, and compression is good, but no spark on the plugs. I also included a picture of the points, which I think may have been replaced at some point. Any insight on that?
http://picasaweb.google.com/danlaurajacobson/Motor
THANKS!!!
