Re: A funny ? about fuel/oil ratios
If you assume that you leave 1/2 an ounce of oil in every quart container (which is probably a reasonable estimate), for every 12 gallons of gas and quart of oil, you're now at 49:1. Getting closer. If you're filling up your 200 gallon tank and not getting every last drop(leaving a full ounce in every quart container), that will put you at 50:1 (49.55:1).<br /><br />If you really want to be a stickler (and you know you've measured the oil exactly), you can just add 6.25 gallons to every pint of oil.<br /><br />Or you can just buy a 4-stroke and then you only have to think about pints when you're at the pub.
