MichaelRouseRN
- Joined
- Jan 27, 2012
- 19
I just purchased this 1988 Sea Ray Seville. I've already had the trailer done and now am getting the engine and outdrive worked on. When I bought it I noticed a little dry rot between the rear box (seating area) and transom. It is roughly 1ft x 2ft. I don't think it has gone under the seat box since when I tap I don't hear a thud, I hear a hollow sound (thank you iboat forum for that info). The rest of the deck is the same, nice hollow sound.
My idea is to cut close enough to the box but still giving me room to work, up to the point that I've pulled back the fiber glass and over giving me enough room to work. Treat marine grade ply with water sealer, then re-glass. Does that sound right? I took a small piece of foam and have soaked it for 2 hours in a glass of water to see if it was closed cell or open (1988???). It isn't saturated and I can only express a little bit of water. It didn't feel wet when I pulled it up near the worst part of the dry rot. Any advice would be appreciated.
