A Modified Flywheel Puller use to access points on 70 Chrysler, 35 HP.
1. I welded extensions to an existing puller to eliminate excess wt. and have strength. It worked!
2. The aluminum bar works well holding the flywheel. Please tell me the flywheel torque spec?
3. Is it normal to have an oil vapor/residue in and around points area or is a bad seal causing this?
4. I?m wondering if I used too much oil in the past trying to get the flywheel off to cause problem?
5. Would it be wise to degrease with a brush and use compressed air to dry and observe again soon?
6. I had not noticed any ill running affects but should I have from the vapor on the point?s contacts?
7. If a seal is needed in the 1970 engine that I have not replaced and owned since 1985, Is It A Pain?
Thanks,
Thanks,
