A quick lesson on Crappie fishing
NathanY
Crappie can be caught all year long. Sometimes they are deep and sometimes they are shallow. I will discuss both.<br /><br />Q. When are Crappie most likely to be caught shallow?<br /><br />A. Crappie are most likely to be caught shallow in the spring and late fall. To find the best Crappie holes at these times of the year is very easy. Look for a brush pile in relatively shallow water 3-10 ft. I like to use jigs, the most productive in my are happens to be flouresent red jig head with a chartreuse body. Once I locate this structure, I go all the way to the bottom and then reel up one turn (of the bale). Then very gently twitch it. Generally the rythm of your heartbeat will move the jig enough. Boat docks are very good types of structure, as are bridge pilings.<br /><br />Q. When are Crappie likely to be deep, and what techniques should I use to catch them?<br /><br />A. Crappie will usually run deeper in the summer time when the surface temp reaches about 80 or so. This will also cause them to suspend. Some good techniques to catching them this time of year are slow trolling and jigging. A good way to slow troll is to take a crankbait like a Hot-n-Tot and troll it as slow as your motor will let you. Trolling the same way with jigs, minnows, inline spinners, and rooster tails are VERY productive this time of year. The more baits you can get in the water this way the better off you are. Now, if you are jigging, go Deep! 20-40ft. Look for a tree that is in 30ft of water that will be the place! If the bite is slow then a little more finesse is in order. Go light with your jig.<br /><br />Q. What is the best way to fish in the winter?<br /><br />A. I like to use jigs over structure in bot deep and in the shallow. Just because the water temp is 35 degrees does not mean the fish dont eat any more. More finesse is required. Downsize your jigs to about 1/32 so that way you get a real slow fall. Now I have caught just as many Crappie in 2ft of water as I have in 30ft of water. This time of year is when you can be glad that you spent the extra bucks on a Fish Finder. Look for that structure, be it a tree, a boat dock, a bridge piling, underwater channel, etc. That is where they are gonna be.<br /><br />Q.I like to use minnows when I fish, what kind do I use, and how do I rig it?<br /><br />A. First, you need to be properly rigged. I like Thill Gold Medal balsa wood Float (CS-03) center sliders. I rig these up with thread type stops and a little red bead. I use a size 7 splitshot and a number 6 BRONZE aberdeen hook. The way that the floats work is that if a fish even so much as breathes on it, it will go under. These are the best on the market. Once you have that done, it is time to choose a minnow. Now it is very important that you "match the hatch." Look at the shad you see the next time you are out, try to get that size when you are at the bait store. I personally beleive that smaller is better. I like to hook my minnows through the head, going up through the bottom lip and coming out the nostril on the top. Crappie will most likely than not attack head first. You will very rarely if ever lose a fish with this type of minnow setup. It also makes them real wiggly.<br /><br />Q. I am going to a new lake, where do I look for Crappie?<br /><br />A. I always look at my depthfinder first. As soon as I leave the ramp. There is no need to hire a guide to do this for you. Watch that depth finder, look for that underwater structure. Look for those bridges, look for those boat docks. Any type of irregularity in the bottom of the lake can be structure and a potential hot spot. Just got to keep your eyes open. If you see someone Crappie fishing, just ask them, where, when, and on what. They wont mind, I know I dont.<br /><br />I hope this helps, if you know something that needs to be added, feel free to add. This is just a quick "crash course" in some of my literal hundreds of techniques, if you have anymore ?'s just ask, I will do my best to answer them. Oh yeah, this applies to mostly southern states due to our climate.
neumanns
Re: A quick lesson on Crappie fishing
Nate thanks for a very informative post, You are an asset to this site.
one more cast
My vote goes to... Nate<br /> I to enjoyed that post, I have never fished for crappie and found your post quite interesting.
moderator1
Ryan. Calm down. You know the rules.
bubbakat
Nate there is some good stuff there. I fish for crappie all year and do it just about the same.
LazyJ
I'll hook the minnow in the lip for trolling, under the dorsal fin for still fishing. In stained water I'll use a much bigger hook, usually a 2/0, sacrificing some bites for a better chance to hang on to the big one. Generally I'll use jigs in the spring and always minnows in the fall. Crappie are HOT around here the last two weeks!<br /><br />I've never given much thought to the quality of my float, I'll sure try that balsa type.
mellowyellow
good advice for lotsa species Nate. I catch a few<br />up here, but they are too small, like bluegills.<br />biggest one ever caught was maybe 8"?
wullumh@aol.com
Regarding crappie fishing...A good way to tell when the crappie are starting to really bite is to note when the dogwood trees flower...check it out!
gonfishn
And don't be surprised in the spring that a Musky happens upon your line.. Many a person fishing for the pooter sometimes gets more than he expects..<br /><br />Very informative Nate..Kinda what I do in the spring when in search for the warrior..Saw Ryans edited post..He must have been having a bed day..I wonder if he even owns a fishing pole.. :D
rayjay
What's a "thread type stop "?<br /><br />Thanks
walleyehed
It's a braided line, small diameter wraped around a small tube in which you run your fishing line thru, remove tube and then pull tag ends tight...movable and yet secure, used for bobber-stop or depth level indicator.<br />Nate, good info...we use very simular tactics up north as well.<br />A long shallow point dropping into a channel or having a channel near the point on either side has been a good area as well...they don't have far to move in cold-fronts or to feed-used both summer and winter. My Nebraska lakes have ICE about to come off, but my kansas lakes are mostly open and one in particular is loaded with slabs that readily hit jigs at 30-35ft fished verticle over the salt-cedar.<br />Fish pattern very simular if you can find the same type of structure to follow up on.<br />Looks good!
SpinnerBait_Nut
Originally posted by gonfishn:<br />Very informative Nate..Kinda what I do in the spring when in search for the warrior..Saw Ryans edited post..He must have been having a bed day..I wonder if he even owns a fishing pole.. :D
Good points there Nate.<br />gonfishn, what else is new? ;)
TwoWatt
Hi SBN :waves<br />Last year was my first year back fishing in a LONG time. I dedicated myself to going after these slabs mainly because "I fish for food" and it doesn't get any better than a plate full of fried crappies. <br />I had a good year, I learned a lot and will continue to learn. I have a few new techniques I'm wanting to try. Just gotta wait for the ice to melt.<br />I can say I tried Nates suggestion of using the Thill Center slider, I didn't like it, a #7 split will not make the bobber stand up (which is what I'm used to). I had to use 2 split shots to get it too stand up, so I went back to my normal. <br />What I use is "The Boss" bobber, it has a spring attached to the upper shaft, when a fish hits, it will pull down on the shaft & compress the spring, so the fish will not feel any resistance until it's too late.<br />Other than that, I have also had great luck on a beetlespin type lure. (fishnspin) Black head/Chart tail, crappie love 'em. Once I stumbled onto a area of baby sized (5-6 inch) crappie. I must of caught 50 fish with that thing in a couple hours, they were tearing it up.<br />Oh well. I'm babbling on like a school girl. I think I'm going for a ride down to the lake & see if the ice is melting yet :D
roscoe
Good writing Nate. thnx 4 sharing<br /><br />There is a great article on the differences in activity and location, of the black and white crappies. Article is in the Feb 2005 issue of In-Fisherman magazine.
fireman57
OldTyme i don't mind my balsa bobber not standing up because as soon a that fish touches it it will stand. Then it has my attention and I get too jumpy and not wait until it goes under to set the hook.
TwoWatt
I plan on doing a lot more trolling this year. I made a nice rod holder setup for the back of my boat. Holds 4 rods (but the law says I use only 3)...<br />I'm buying two 10 foot noodle rods for the outsides & just use one my 6.5 footers for the middle. <br />Plan on just using jig/minnows. I'm not sure if I will use bobbers or not, we'll see. <br />I had good luck trolling those spins last year, but my boat control sucks. Catch a fish & get way off track... I just need practice.<br /><br />Wait, what's that sound....?<br /><br /><br />Oh it's ice melting =)
rolmops
The adjustable slip bobber is a nice touch.I use it whenever I fish with a short pole.<br />I do prefer my 17 foot telescope rod (mitchel)with bobbers and sinkers that I get from Europe. They are much more sensitive than our American bobbers because they are developed for long pole still fishing.
