GranvilleDave
- Joined
- May 12, 2015
- 10
I bought this boat from a 'friend' ('74 Avenger 16.5' with '74 Johnson 50 HP (re-homed to this boat)) and it included 2 props. I've tried both with totally different results and think I may need something in the middle. Here's what happened.
Prop 1. 14x11. Ran it 2 times (both without the Tach configured, I know that I need to retest with the Tach but wanted to float this out to the forum for your thoughts and input). Test 1: My wife and I, calm day, very light tail wind, boat was slow to get up on plane and would run 22 MPH WOT (again, not sure of RPM) here. Test 2: My 'friend', his friend, and me, slightly choppy lake and the boat would not get up on plane. I didn't even measure speed. It seemed that my 6.5 kicker pushed the boat as fast as my 50 HP!
Prop 2. 13.25x17. Test 1: My daughter and I on a calm lake, the boat would plane very easily, but the top speed was only 17 MPH and the RPMs would exceed 8,000 at WOT. Of course, we would not leave it at that level for longer than the test.
It looks like I need something in the middle. Would you recommend that I retest Prop 1 and look at the RPMs, or just choose a 14 pitch prop and be done with it?
Thanks for your thoughts. Assume that all 3 adult men, weight about 250 lbs and my daughter is about 150 if that helps in your feedback.
