Caveman Charlie
- Joined
- Oct 31, 2007
- 545
I have a 1973 boat with a mercruiser 140 I/O .My engine compartment always smelled strongly of gasoline. I saw on here where some other members said the same thing so I just thought it normal. A couple of weeks ago I got my boat out of storage for the first time this year. I had removed all the old gas from the gas tank for winter storage. So, I dumped a few gallons in out of a gas can to fire her up. My boat has a fill hose that runs between the fill port on the top of the stern and the tank mounted under the rear seat. After dumping gas in I noticed a few drops of gas seeping from this hose. I removed it and found it was just full of holes.
No wonder it always smelled like gas back under there. After I replaced the hose there was little if any gasoline smell under there now. I recommend that any one with a older boat replace this fill hose. Even if gas is not seeping out of it during filling like it was on mine the hose could still have holes on the top side allowing gas fumes to escape into the engine compartment.
Also, get the correct type of hose. This is a special hose with a anti-static wire built it. As I replaced mine I made sure a end of the wire was sticking out of the end of the hose and I stuck it under one of the hose clamps that hold the hose on. I also stuck a piece of electrical wire under that clamp and ran the wire to the same ground on the back of the boat where the gas tank and other things are grounded.
My boat is much safer now. IMHO it would be a good idea to check this hose every couple of years and replace it every so often.
Have a nice day
Have a nice day
