AAAAAARGH!!! #$!"#!" distributor module!!!
ss9940
Hi all!<br /><br />I've been posting a lot of questions lately about the timing issues - now i discovered that A BRAND NEW DISTRIBUTOR MODULE was malfunctioning. It simply stopped working after i shut down the engine. It ran fine (at least i think) when the engine was cool & running, but when i wanted to restart the engine, there was no spark at all. I also had backfire, although i set the ignition to 0 deg TDC. I think the module didn't advance the timing when it supposed to, or it partly worked, partly not. WHAT A BUMMER!!!<br /><br />I replaced it with and old module, now it works perfect. I barely touch the key and it works!<br /><br />Still got a question that i posted a while ago: <br /><br />
<br /><br />The label says to set the base timing at 6deg BTDC. Does that mean in base timing mode or while running? If it means while running IDLE, how come that 6 cyl has base timing set at -4 ATDC? It doesn't make sense. If 6deg BTDC means in base timing, than that would bring up like 13deg while running (if i did the math correctly).<br /><br />Any ideas?
ss9940
Re: AAAAAARGH!!! #$!"#!" distributor module!!!
Hmmm... noone has any ideas how this is possible? I think i'll have to contact Delco then and ask them about the matter... :D
MATMAN29
base timing is with engine running but with purple and white wire grounded out.(should be on top of engine somewhere) good luck
