aAlpha One- Water tube.
Kim1349
Without replacing bellows, we want to replace the water tube.
From the book it looks like it can be removed on the front by taking out two bolts inside the transom aft of the motor, correct?
Is the length shipped from Sierra the correct length or does it need cut? If it needs cut to what length?
Comments or suggestions on replacement?
Thanks
Sparks
Bt Doctur
Re: aAlpha One- Water tube.
and how would you remove the clamp from the inlet tube let alone re-install the hose?
housing and bellows need to be removed
Kim1349
Ok, the book looked like you disconnected the engine side inside with two bolts and then pushed the tube through. So does the new tube come the right length??
Bt Doctur
The tube is almost never replaced, only the hose. You do have the manual from the Adults Only section, right?
page 4B-4
Kim1349
Ok.. I take it your serious. Where do I find these manuals?
Bt Doctur
the very first thread
-------------------------ADULTS ONLY-------------------------------
Kim1349
Thanks for the "ayah"
What does winterizing have to do with my questions?
Kim1349
Sorry, I saw Adult # 6 was winterizing. Thanks much for the link. Appreciated!
loud2222
hello... can someone help me with replacing a fuel pump on my mercruiser 3.0L? I have to get the engine on its "lowest downstroke" or i will damage the new pump... how do you do that?
84EdH
you should start a new thread to get this answered.....
