replacing my two batteries with a starter and deep cycle--- need advice on making this work --- an issue I'm having currently is the motor running turns off the fishfinder/gps while underway- I would assume wiring at such and leaving the AB switch on "A" will alleviate the problem- assuming i don't need to recharge the deep cycle during the trip.
at the moment I have 2x deep cycles, no trolling motor (yet).
Did I get this right, or is there a problem with this design? Basically, charging the batteries before leaving home- and if I get stuck not cranking I can go to "AB" for an emergency start--- ?
