a question for you guru's out there. 1979 Johnson 115. dropping #1 cylinder. I've changed the coils around, after testing spark at 7/16" gap on the tester and it seemed weak. I changed it out with the #2 cylinder, but in doing so, I found the paint preventing a good ground. I made sure to scrape the paint down to get a good ground, on both spots when mounting the now switched coils.
This did seem to make a difference. Today, took it out to the lake with a friend of mine who has a timing light. It ran GREAT when we first got there, rode around for not quite an hour. Headed back to the ramp, having to come to idle while passing under a bridge. Before going back up to speed, we sat there discussing what all I'd done to the motor while it was sitting there idling, maybe 6 or 8 minutes total idling under the bridge and us shooting the breeze. Went to power up to get on back, and it wouldn't come up at all. he put his light on #1, and weak to no signal on that plug. We didn't have the time when we got back to the ramp to swap the power packs around, and he needed his timing light so I couldn't borrow it for using in the morning to switch the packs around and test the firing again.
My question is this, a power pack is either good or bad? or is it possible for it to be ok, then 'bug out' and drop a cylinder? Before you put in the link for the CDI page, I've been there looking at it already, I don't have the right meters to check the DVA, on the packs or the stator. Is it time for me to bite the bullet and go put this in the shop, or should I try just picking up a power pack and switching it out first? that would be the cost of the pack obviously, but it would save me the cost of the labor at the shop. I guess I could go rent or buy a timing light and change them out and test it. The thing is, when we put the light on it when we got to the lake, it was fine. So again, is a power pack one of those 'either it's good or its bad' kinda things, or is it possible to be fine for a while, then bad for a while, then fine again, etc etc.....
As always, thanks in advance for any help and advice! Chaz
