? about reverse lock out
aspano1
I've searched and still I'm confused about reverse lock out on 88 Evinrude 50 HP. that at some point in it's life had Tilt/Trim. When I got it all had been removed, I use on a 18 ft. pontoon. When I shift into reverse it kicks up out of the water. Now short of replacing T/T, is there something else out there that will keep this from happening. Thanks for any input.
boobie
Not much choices. Get a power tilt unit or go to salvage yards and convert it back to manual. OR, tie it down some how with a strap but that's no good if you hit something.
bonz_d
Or start watching for a donor engine. I just picked up a 1980 50hp Evinrude for $90.00 and yes it is complete. I'll bet the scrappers want more than $90.00 for the parts you will be needing.
Yes, you need to convert back to the manual tilt pieces.----There is time involved for a salvage yard to remove these pieces.-----Depending on your location there should be lots of those pieces available !
bonz_d
There is time involved for a salvage yard to remove these pieces. Depending on your location there should be lots of those pieces available !
Correct! So then you have to ask yourself how much is your time worth? Myself like many I have more time than money.
Look at it this way, there is a mount on each side of the exhaust mid section and 2 bolts below the powerhead. Both whole units can be swapped out in an afternoon.
I am well aware of the concept of shop time / hobby time / do it yourself time.---Also aware of the folks with old motors looking for repairs on the cheap.---Remember that your motor may be old , but the shop time is ---" all brand new time "-----Nuff said.
bonz_d
So what is the point you are trying to argue? I'm not questioning the "Shop Rates" that are charged. As with any other service there is the "going" rate. I take my truck to a shop all the time and pay their labor rates and don't have a problem with that. They have the tools and expertise to do the job that I can't do or can accomplish it much quicker than I can.
