Ready to give up on this 87 force 35. Changed the fuel pump diaphragm (the old one was fine), cleaned/adjusted the carb, getting spark, getting good compression. But I don't have a midrange, the motor runs fine at wot and fine at idle. Put the throttle anywhere in the middle, and the motor will start to wind up, then violently shake and drop rpms, over and over. Like an extremely bad misfire. After I replaced plugs, it seemed to run better. After I adjusted carb it ran better. But eventually it returns to running like before.
Some of the wires from the stator look heat damaged. Looks like the battery shorted them once. I wrapped any spots where patches of bare wire was with insulation. Should I pull the stator? Could something like that cause misfiring only at mid throttle? That flywheel nut is an absolute beast to remove though..
