About Volvo penta Exhaust Riser Overheats
ilkeraslan
Hi and have a nice day I have bought beneteau gt 38 with 2x300 diesel enginie. while I drive right enginie information display says
Exhaust Riser Overheats decrease rpm.
What should I do
My enginies are 18 hours.
Re: About Volvo penta Exhaust Riser Overheats
What should I do
Ayuh,.... Welcome Aboard,.... Change out it's raw water impeller,....
That's Always the 1st thing to do in Any overheat situation,...
Grub54891
18 hours? Talk to the dealer about warrenty work. As Bondo says the impeller is the first place to check,it could have gotten a " set " to it from sitting around before you bought it.
Grub
ilkeraslan
First of all thank you for your help my firends.
I called dealer and they send service. We drive together between 1700rpm and 3600 rpm. We did not see ant alarm about exhaust. Bu the serviceman said " sometimies this type of electronic information displays can show error. He also connected his computer to ecu. And control the temp. Everyting is normal. :) But he did not chech impeller. Now I gonna call him.
Thank you very much. I will inform you... :)
