Re: AC/DC converter and the battery charger
Input to the converter is 117 volts AC just like you have in your house. The converter passes that voltage through to the 117 volt outlets and applicances on the boat if the breakers are turned on. Obviously if they are turned off the outlets will be dead. The converter also takes 117 volts AC and converts it to 12 volts DC for your low voltage system and for battery charging. So yes -- you can run both AC and 12 volt DC stuff at the same time. That's what the converter is for. Now if you had an INverter, it does the opposite. It takes 12 volt DC battery voltage and turns it into 117 volts AC. However, this is a losing proposition since the batteries don't last long working that way -- for example running an air conditioner, coffee pot, electric heater or any other high current draw items. For that you need a generator.
