Greetings,
I'm trying to picture how I should go about setting up my charging system with an additional solar panel to provide power both while in the dock and out on the water.
My current setup is a 24' Invader V250 with one cranking battery and one house battery with a 1/2/ALL selector switch between them and no charger. There is no isolator between the two batteries and the single altenator. There is shore power available but with no genset. No AC-powered equipment will be needed while on the water, however I want to continuously run a small DC fan and the stereo for 8+ hours.
1. Will a 5A on-board dual-bank battery charger be enough to charge both batteries while on shore power, while having the DC fan and the stereo on? (sleeping on the boat overnight while at the dock)
2. Will a 3.5A solar panel (no regulator) be enough to operate the stereo and DC fan for 8+ hours while on the water while providing some charge to both batteries, assuming strong sunlight? Do I need to add a diode for a small panel like that?
3. How and where do I wire up both the on-board charger and solar panel? I understand how to hook up one or the other individually, but are there any problems with having both? Will a switch be needed between the two?
Thanks in advance - let me know if any additional information is needed.
-Tobias
-Tobias
