mtfoyre
- Joined
- Jun 13, 2006
- 42
Yesterday was only my second trip to the lake with my boat. The first trip ended w/ a gasket failure and 900 dollars worth of work to the sterndrive
Anyway, I noticed it takes a really long time to get to 4000 RPMs. Somewhere between 60 and 90 seconds. It immediately jumps from idle to 3000 RPMs; bow runs high and will start to plane around 3500 RPMs. It will literally take about 10 seconds for every additional 100 RPMs over 3k.
Once you get there though, it takes a lot of hard turning or extreme chop for the RPMs to drop and have to rebuild. It also isn't affected by dragging a tube...it will accelerate the same with or without a tow.
I'm wondering if this is (in part) because of the prop.
boat: 1967 Thompson 21'
weight: uncertain but I know it's a lot
engine: Mercruiser V-8 185hp (can't remember exact displacement)
recommended RPM: 4000 - 4400
sterndrive: ~1976 OMC
prop: 15" 13p (it isn't stainless...my mechanic told me it was bronze, I think)
I know that I have a lot of kinks to work out, but as I go I'm wondering if I should consider a different prop to get up to speed quicker.
Thanks in advance and I'll try to get any other info needed. I have the manuals at home but the boat is kept at a remote storage location.
