I moved the CMC tilt/trim unit from one hull to another identical hull, and like a doofus, drilled the holes in the wrong spot...on the old hull, the CMC was mounted as far up as it would go, leaving the top of the plate mounted over the aluminum strip at the top and leaving a small gap between most of the unit and the transom since it was mounted on a bit of an angle.
I thought this was sloppy, so mounted in on the "new" hull so the top of the CMC was just below the aluminum strip....then found the outboard mounting bracket hit the aluminum near the middle of the tilt range...doh!
So I'm going to remount it higher, using some thin aluminum plate to shim the CMC out so that it clears the aluminum strip at the top of the transom, and can still fit flat to the transom.
Good idea? Horrible idea from someone who has no business being around boats?
